Chassis Corrosion - Dynaco SCA-35
Well it bothered me enough and I was confident enough in a fix that I delved into chemistry and found that oxalic acid in a 10% solution was able to remove oxidation and make the chassis look brand new (using a fine paint brush on the spots). You old dogs can still stand to learn some new tricks. After removing the corrosion, wiped down with some WD-40 and ready to move on with the restoration. I really appreciate your help and I know that sometimes I'll have to explore on my own and figure out a solution for the future amp heads who will undoubtedly have more and more rust and corrosion as the years pass by.
I'm glad that it works for you. I am just happy knowing I've stopped the degredation. It's really cool when someone goes all in!
Hi all,
I've become a Dynaco fanatic and have started buying and rebuilding various amps to gift to friends and family. I just received one off the bay and electronically it looks pretty good, was previously recapped and resistored. However, at some point prior to being sold off, someone got it wet and it now has a rust spot on the back and dots of corrosion on the interior chassis. What would you do to treat this so it doesn't get worse, or is it possible to even repair? I don't especially want to disassemble the entire amp to paint the chassis although I probably will if there isn't another option. From my very light research I read that these SCA-35 chassis were painted, and then some say that they are cadmium coated. Any info on this?
To clean the chassis use WD-40 sprayed on some 0000 steel wool. Spray some wd40 in a plastic up, use that to re-apply do not spray the amp with wd-40.
Scrub the chassis with the steel wool and wipe off with paper towels or shop towels. It’s best to do this if the chassis is bare.
That will take the rust down and allow the shine to be restored. Buffing with any buffing compound or waxing can be used after to buff to desired shine.
Good luck with it! Welcome to the site too.
index.php
I've bought several vintage amps with those tiny brown-black dots. From the amp's history, they may be cigarette smoke tar droplets. They are very hard to remove. Rubbing alcohol and Simple Green works a little, but I end up leaving the dots alone.
My Silverface 1968 Fender Bassman. Spent its life working in a bar. :)
In my opinion and experience, all those little spots are German cock roach`s excrement, Boochie ! Eww !!
After playing for hrs. the amp`s chassis, transformers remain warm for a long time, and the little buggers crawl into the amp through any open input/output 1/4" jacks, especially during cold weather and the bar/club shuts down over night and becomes cool/cold inside looking to stay warm.
The light brown stains are second hand smoke cigarette tars that were air born and drawn to the amp from the rising heat convection during use, especially being the Fender amp`s tubes are hanging upside down as mounted on the chassis underneath, and I`ve always been able to easily remove the tars using Glass Plus, Windex, or Simple Green.
All Bars, clubs, and even some folks homes are filled with roaches feeding on all the missed spilt beer and liquor sugars, and any food particulates, if served !
I became accidently very aware of the Corral Gables Miami located club`s roach inhouse density situation in 1980, when I was setting up the band`s PA and had a leftover ~6" strip of gaffer`s tape and so not to waste it in case I might need a piece later I folded the end and stuck it to the wall with the sticky side out beside my mixing board, and it became completely covered in stuck German cock roaches that crawled across it over night for about a week !
No, they're tar stains. As I cleaned them, you could smell the tobacco. The cabinet needed Simple Green treatment, hose spray, and a couple of days in the sun to eliminate most of the tobacco smell.
When I bought it, I knew that it was a "house amp" in a bar. I got it for half the price of most drip edge Bassman on the market. The tolex and grille cleaned up nicely. You should have seen how brown the initial rinse water was!
After resto with the DIY 2X12 cab I made for it.
I don't have a "before" photo, but it looked like this.
When I redid the amp, a guy online made face plates for most of the blackface and silverface era Fender amps. They were done precisely and included all the changes within the same model, like where the vertical lines were placed or not placed.
I'm a working musician, if your stuff ain't stinky and kind of abused have you really been gigging?
My corrosion problem is a bit different. I have a (different) Fisher X200 that has the bias/balance switch locked up due to corrosion. Anyone ever deal with that before?
Yes. I used Deoxit Fader Lube F100. Let it soak overnight. The next day, slowly try to move the shaft in each direction. Just a little at a time. Add a few drops of Lube if the control is still stuck. It works in most cases, except where the potentiometer is damaged and physically frozen, not corrosion. If that is the case, then you need a new pot.
https://caig.com/product/deoxit-fader-f100l-l25c/
