I'm posting this to avoid derailing another recent discussion where the topic of grounding came up as a side issue. In that thread, I mentioned that all my recent projects - amps, line stages, phonoe preamps - isolate signal ground from the chassis. The chassis is only connected to the third wire earth ground. This eliminates hum from ground loops. Member @SS904 then noted he had done the same in an amplifier, but he added a 10 Ohm resistor and .1uF Y2 cap from the cap bank ground plane to chassis. When I asked about the purpose of those parts (which to me appear only to reintroduce the possibility of 3-wire ground loops), he said the path through those parts is "enough to break the ground loop and still provide a measure of safety beyond simply floating signal."
So, my question for @SS904 (or anyone else) is this: What potential safety issues might occur when signal ground is completely isolated from the chassis? Why is it important to maintain some type of connection between signal ground and the chassis (third wire ground)? I'm just trying to understand why this approach might be advisable.
Jack
Jack
