"Antennas are mighty finicky and I'm no expert, but adding 140 pf of capacitance doesn't seem good."
The idea that capacitance on the feedline is bad has no relevence at all. The transmission line equation which calculates the input impedence from the load impedence has no parameter for feedline capacitance. However, It does use the impedence of the transmission line as a parameter.
All 2 wire transmission lines have a certain amount of capacitance/foot between the wires, as well as inductance/foot.
Perhaps you're thinking about the ramifications of phono input cable and high capacitance of the cable having an impact on the signal. This is because of the very high input impedence of the phono input. And only when you're around 1000 pF total capacitance is this going to be noticeable.
Antenna feedline capacitance or inductance has no bearing at all on the signal received.
The capacitance between conductors in Cat 5 cable is a concern for transmitting data over distance and will effect the bandwidth. When he twisted the ends of the Cat 5 together he effectively made it one multistrand conductor and the capacitance was shorted. The capacitance measurement of the cable is meaningless.
With all due respect, RF transmission lines are characterized by
their distributed capacitance and inductance, and although users
don't need very much to care about those things, these parameters
are far from meaningless. They have practical consequences, for instance,
a short at the far end of a cable that is a quarter-wavelength long
is seen at the input of the cable as an open circuit.
Please do study some adequate material before making erroneous
statements. A good starting point would be the ARRL Handbook.
Regards to all.
If you're discussing my credentials, I am a holder of the former
amateur, advanced, and digital Canadian Amateur Radio certificates,
I was tested for Morse Code at 15 WPM and I also hold a Ph.D.
in electrical engineering with a specialty in microwave circuits.
Let's have a discussion about any problem in radio technology anyday!
73 de VE2GTP (ham since 1982)
P.S. : stranded antenna wire is fine...
I just thought he was talking about twisting the end on some leftovers rather than going out to buy some new single conductor to make an antenna.
Assuming one didn't want to get the balun and deal with the coax...what are the repercussions of just using 300 ohm twin lead?
Without a balun, you will get reflections back up the antenna due to mismatch. 100 ohms to 75 ohms isn't close enough. If you use twin lead you will pick up interference and multipath through the twin lead. Invariably I have gotten much better reception with any antenna if I use a balun and 75 ohm coax, rather than twin lead, even over a 6 foot length.
