Ilikevinyl
Cool Breeze
I used some rubber o-rings on my Thorens TD-160 & Technics SL-1650. They really helped, both turntables sound better. I have a much blacker background on both. Soundstage is more precise. Bass response is much tighter sounding. A cheap tweak that works!
I bought my rubber o-ring kit on Ebay. It has all kinds of o-ring sizes. Don't ask me what sizes I used. The kit came all messed up and I had to sort everything out. All the o-rings I used fit nice and snug. They definitely won't move around.
Thorens TD-160:
I put a bunch of the rubber o-rings around the platter bearing underneath the sub-chassis.
Put some around the platter bearing on the top of the sub-chassis.
Put a bunch around the safety post, that is also connected to the motor bracket.
Here you can see that I put some on the screw housing underneath the Sound Support arm platform.
Finally, put some around the spindle.
Put some on my SME 3009 Improved arm. 8 of these o-rings weigh .6 grams. Took off the headshell in order to slide them on the arm. The non-removable headshell does come off. There's a tiny screw underneath the arm near the headshell that has to be removed first. Then twist the headshell off. If your going to do this, I highly suggest you take off the arm from the turntable. You don't want to loose that tiny screw! Put 3 o-rings next to the bronze bearing. 2 spaced out in the middle of the arm. 2 right next to the headshell.
On the Technics SL-1650, I only put them on the tonearm. 2 on each side of the pivot housing. 2 on the rear counterweight shaft, as far forward as they would go, nearest the arm pivot.
Put 5 o-rings on the arm tube.
Just thought I would pass on this cheap turntable tweak to my fellow Vinyl Spinners.
I bought my rubber o-ring kit on Ebay. It has all kinds of o-ring sizes. Don't ask me what sizes I used. The kit came all messed up and I had to sort everything out. All the o-rings I used fit nice and snug. They definitely won't move around. Thorens TD-160:
