This thread is getting some interest. Check out the number of views!
It's the "cheap" in the title.
I just ordered an assortment of o-rings myself. And being cheap, I found a 225 rings set for less than $6 shipped.
Yes, heat shrinking is another good way.:thmbsp: Do one or the other with your SME, for sure.
I just added the O-rings to my SME just like you did, and sure enough, there is an improvement in the bass and mids, and there are better dynamics. :thmbsp:
A couple of years ago I tried a thicker o-ring around the fastening ring for the headshell. It did sound to me that it made a difference, although a subtle one. I thought it was me dreaming but there may be something to it.
I have an Ortofon test record with a track for visually verifying resonance frequency. I might try this again.
I only have one or two such rings. I will give it a try once and check if there is a measurable change in resonance frequency.Try the test a number of times, each time with an extra o-ring. Try as many as the OP has. Obviously there are cartridges which prefer to be used on a heavier arm. The addition of mass would benefit that type of cartridge. Either way; benefit means change asmuchas detriment means change. The addition of mass for one cartridge might mean benefit. The addition of mass for another cartridge might mean detriment.
The number one recommendation I could make for this method is that it is easily reversible if one didn't like the results and it is cheap as chips to experiment with.
It will be interesting to know if just one or two rings affects the resonance frequency, as that could be the benefit of these rings, rather than just adding mass to the arm.
