That is, quite literally, how Matthew Polk & company (Polk Audio) got started.Back in the 70s, a friend of mine and I decided to build some counterfeit Bose 901s (I already had a real pair of Series 1). I bought a couple of cases (enough for 3 pair) of 4" Bose drivers from CTS in Paducah, KY. My friend built two pair, and being an architect, decided to make some rather elaborate cases using solid birch tops and bottoms. They still look and sound great. I never got around to building my pair but years later my friend's Marantz 250 amp decided to apply full DC supply voltage to one of the channels and smoked it. I donated my unused set of drivers for the repair.
modelnine by Mark Hardy, on FlickrYa, those earlier Marantz power amps weren't the most stable. I've had a few. As long as you follow all the service bulletin updates it does go a long ways to making them more reliable though. CTS did make a lot of drivers for various brands. I still have a few pairs of speakers using all CTS drivers.Back in the 70s, a friend of mine and I decided to build some counterfeit Bose 901s (I already had a real pair of Series 1). I bought a couple of cases (enough for 3 pair) of 4" Bose drivers from CTS in Paducah, KY. My friend built two pair, and being an architect, decided to make some rather elaborate cases using solid birch tops and bottoms. They still look and sound great. I never got around to building my pair but years later my friend's Marantz 250 amp decided to apply full DC supply voltage to one of the channels and smoked it. I donated my unused set of drivers for the repair.
He gave me the bad 250. It turned out to be the Darlington had a leaky collector-base junction that drove the output stage to the rails. My 250 was an earlier model that did not use Darlingtons. Right now, I've got both 250s but each one has a bad channel. Fixing them is on my to-do list.Ya, those earlier Marantz power amps weren't the most stable. I've had a few. As long as you follow all the service bulletin updates it does go a long ways to making them more reliable though. CTS did make a lot of drivers for various brands. I still have a few pairs of speakers using all CTS drivers.
If you aren't using the LWE feedback circuit, you can send it to me!Gents i'm in a process of converting a pair of LWE Model 1 speakers, in order not to use LWE feedback. this will probably will require a change in the enclosure size and of-course a new crossover. AFAIC the woofer in this set-up is CTS 15" model 5805026. Where may i find the woofers parameters / specs?
thanks much!
