I do 7 with plenty of space to spare, in front, rear and in between LPs.I wonder if you could do 6 LPs at a time w the 10L tanks.
I put just under a grand into my US set up. 10L tank, @ETLS spindle system (best there is out there IMO), heavy duty motor, two large bundles of MF towels, 25 gallons of D H2O, 40PSI hand sprayer, Discdoc brushes, power interrupter (makes motor spin slowly, at any speed I choose up to limits of motor), Thunderon brush (de stat after vacuum), stand for holding tank and spindle set-up, vacuum, a first round of chemicals, 0.005 micron filter and pump system for cleaning fluid.
edit to add:
Looking at receipts it looks like it was closer to $700 all in. And the puck system is now coming down in price according to AK seller.
For drying I use both dish drains and an old vertical CD holder I lay flat. I can wash and dry 28 or so in a run.
From beginning to end, when I first turn on machine and get a stack ready to go until all in drying rack (drying can be a long time weather dependent) it is over an hour and closer to 90 minutes it seems. I run 7 at a time for 15 minutes. Then if I am in good practice I can do secondary wash and rinse in 15 minutes while next batch is spinning in US. It takes a few minutes to load and unload spindle carefully. As I have been out of practice I can't seem to get all 7 done in time so they pile up and after third run I have about 10-12 in sink awaiting secondary wash. Then I run the filter for about 10 minutes before a drain and refill. I run water through filter into a separate tub after 10 minutes recycling through filter. Then wash the tank and put water back in. After several runs (100+ records) I may discard water if it looks too dirty. It all depends what I have been washing.28 at a pop is more the production I'm looking for. At 7 a cycle, would be just over an hour to do 28 LPs?
I have a space for discs to be cleaned or recleaned.
At about 50, I get after them. A couple at a time would take forever.
I'm not terribly patient.
LOL. Check the Record Cleaning compendium on AK. You will see agreement on these types of things is far from settled law.do we all agree...TergiKleen is the best thing to add to your distilled water?
Shocking amounts of crud are in bottom of tank after washing pre rinsed LPs. I like to use a very gentle pre rinse so as not to scratch depending on what is on there.At this point (subject to change) I plan to run the LPs thru the Spin Clean, vac, then the US so the LPs would be pretty clean before the US.
Experience will tell if thats beneficial or a waste of time.
I think it might have value esp on used LPs. If gotten some pretty cruddy ones that clean up fine but its a lot cheaper to change out the Spin Clean water than a 10 L tank.
I bought a very small pump , some hose and a 0.005 micron filter. I may be able to find the info on Amazon if you like. Not hard to find that stuff on web if you search. Filters end up being the biggest cost as you need to replace them.Hey Dfunghi, how do you filter your water?
Thanks
If nothing comes off the record then there is no point in using the US. I change my water every few months. The Tergikleen has a flocculant so the water stays pretty good for a while, just the bottom gets a sort of a film.At this point (subject to change) I plan to run the LPs thru the Spin Clean, vac, then the US so the LPs would be pretty clean before the US.
