Scott -- the value you are now using for your feedback resistor (3K) to produce the feedback reduction you indicate (18 db) is completely in line with what would be expected for the changes made. By changing the ECC83 stage to a 12BH7 (a very good move), the open loop gain (OLG) has been reduced significantly, meaning that the feedback resistor needs to be reduced as well to maintain the same relative amount of feedback.
Also, because of reduced Miller Effect in the 12BH7, the HF response of the OLG model has now been increased. This -- along with the reduced value of the FB resistor -- required the feedback cap to be increased significantly to achieve the same relative response characteristic as before.
So now, on to the most important question: were these last photos taken with or without a step network in place?
Dave
Dave
