Nyjblbob
Hooked on Horn's and Tubes. Go big or go home
Thanks for thatWell, the biggest thing is that they make tubes last longer...back in the fifties the JAN testing proved that reducing a tubes envelope temp had a great effect on increasing tube life, my Collins R-390/URR and R-390A/URR are just filled with tubes and were expected to be on duty 24/7/365, and the IERC tube shield were developed for just such instances.
I do not find any sound degradation with the Pearls installed, and if it ends up costing me a lot less for tube replacement, especially the NOS tubes in the front end of my MC240, or the replacement tubes for the Audible, then it's a good thing...
And no, I have nothing to do financially with Pearl, I'm just a very satisfied owner.
I am also observant of the fact that the entire amplifier runs cooler, whether it's my VTA-70i or the 240, and the room doesn't get as warm....it radiates the heat from the unit more efficiently before heating the entire unit warm up to higher temps...my digital IR thermometer confirms that the chassis even runs much cooler when the power and input tube temps are brought down...kind of like back in the day putting a better radiator in a hot rod along with an external oil cooler helped keep the engine cooler even in 100+ degree weather here in Texas....been there, done that.
Makes a lot of sense
I use a fan after the power transformer warms up
Pearls don’t need to be plugged in
Bobhorn
