I bought it all from Mouser. I used perf board with a 0.100" grid. The turrets I chose fit in a 3/32" hole and are by Keystone Electronics. I had to search through the Mouser and Keystone web sites to get all the details and be sure it would all work together. Since then I have also found plans for a DIY staking tool on the Tube Depot web page. Not sure how well it would work with the turrets I purchased. I staked the turrets in my drill press. You have to make a holder for the staking tool anvil. I drilled a 1/4" hole in the edge of a 3/4" thick board and inserted the anvil. Make certain to leave it protruding enough that already installed turrets won't hit the board. I will make something along the lines of the Tube Depot DIY tool anvil for the next go around but will keep the Keystone swage as it has a rounded forming profile that would be hard to duplicate DIY.
From Mouser:
Turrets Keystone p/n 1514-2
Staking tool Keystone TL-5
Perf board Vector 0.100" grid, 0.062 thk, p/n 169P44 (I had some of this board so didn't actually use the Vector which I purchased) You can used non perforated board and other thicknesses but will need a different turret number to fit the particular thickness of board.
The DIY staking tool is at:
https://s3.amazonaws.com/tubedepot-...ched_files/turret_swage_fit_v1.pdf?1382029920
John
