Hello everyone,
I'm working on my first Harman Kardon Citation V using the complete McShane rebuild kit. I've emailed Jim, but I know he's busy, so I thought I'd ask those with firsthand experience.
What are the advantages and disadvantages of keeping the original capacitor values versus installing the larger values? I'm assuming this has to do with amplifier stability and HF compensation, but I'd appreciate hearing the reasoning from those who've done this rebuild.
I've read another thread suggesting these were added to compensate for today's higher line voltages (115–125 VAC instead of the original 110 VAC), reducing the heater voltage from around 6.3 V to approximately 5 V.
Should these resistors be added if they aren't already present, or is it better to leave the heater circuit original?
The notes simply state that C4 is not replaced, but they don't explain what should be done with the wiring that originally went to C4.
Also, the McShane Citation V power supply schematic with the choke still shows C4A and C4B connected in parallel with the secondary winding feeding the DC balance pots.
I'm having trouble reconciling the schematic with the physical wiring.
Can someone who has completed the choke conversion explain exactly what happens to the original C4 connections and how they should be rewired? Photos would be greatly appreciated.
Thanks in advance. I'm an experienced electronics technician, but this is my first Citation V restoration, and I'd rather ask questions than make assumptions.
1. Feedback Capacitor Values
My amplifier originally has:- C10/C16 = 47 pF
- C6/C12 = 220 pF
- 100 pF
- 430 pF
2. 12BY7A 1K Resistors
My amplifier does not have the 1K resistors associated with the 12BY7A tubes.I've read another thread suggesting these were added to compensate for today's higher line voltages (115–125 VAC instead of the original 110 VAC), reducing the heater voltage from around 6.3 V to approximately 5 V.
3. Choke Upgrade / C4 Wiring
My kit includes the choke upgrade, which installs where C4 is located.The notes simply state that C4 is not replaced, but they don't explain what should be done with the wiring that originally went to C4.
