So just a little update as far as this goes.
As some of you know already,
over in the DIY forum I've been working on the panels and veneer and stuff. And just a little while ago, I've 'almost' finished the first of the panels. Although I made a set out of plywood and then veneered them in some plain grain veneer I found here at the house, I also ended up getting rosewood burl, and have been simultaneously working on that as well.
Still have a final gloss to put on it, but this is how it turned out:
That's the original Sony panel, which has had the old plastic edge veneer removed, melamine 'wood' face sanded down sufficiently to bond, corners reformed, then veneered in rosewood bubinga raw veneer finished with several coats of teak oil for the moment - (and for the purists, all stuck together using hide glue). LOL
So there's one panel, now to start on the other which will be fully mirrored/bookmatched with this first one. Once all done, we'll final gloss them together.
So glad I decided against cutting down one of those crappy shelves like I was thinking. LOL
