Now you’re getting somewhere!
Next, disconnect the transformer from the power board and repeat the test.
This will tell you if you have a damaged transformer or bad power supply.
You really should make a dim bulb tester though to prevent tripping the breaker and protect the unit from further damage.
okay.. So a little explaination of how the circuit goes....
Transformer wires go into the "power board".... Which consists of 4x Bridge rectifiers, and bank of Main filter caps....
Then a few transformer wires go directly to the back PCB board, Where the speaker terminals and In-rush current circuitry is...
I disconnected all the wires that go from the transformer, To the "power board" (rectifiers and filter caps board), But left the wires connected from transformer to back PCB.. As the power switch is connected on the back PCB too...
Powered it up... No lights in my house dimmed, No breakers tripped, No funny noises etc... Just a nice gentle hum from the transformer, As you'd expect.....
So...... Being as the Transformer is connected to the back PCB in-rush current circuitry, It tells me that the in-rush circuit is fine?!?!
So..... Power board is at fault?!?!
As it only dims my lights and occasionally trips my breaker, when thats connected to the transformer...
On a side note: I did think i was getting a strange reading, last night, When i checked the Bridge Rectifiers with a muiltimeter.... Plus... When looked at closely.. the solder points for the rectifiers, are dull, grey and look iffy......
So maybe i wasnt seeing things earlier.. maybe there actually was a blue spark from the rectifier pins?!?!?!
