Grenadablues
I recently acquired this receiver which was dusty but otherwise functional. No appearance of any service performed. I cleaned the unit internally and Deoxed the pots and switches. Under power the unit has a minor 60 Hz hum on the phono inputs but the aux in is quiet. Those are the only two inputs I have worked with to this point.
Regardless of input, the unit clips when the volume is taken to about 75 percent or greater. I would appreciate opinions on this clip and/or hum. My thoughts are the hum may be due to a poor ground (which I have not addressed so far). OR the hum and clip might be due to weak failed caps on the power supply. I am not using this unit other than to test.
I would like to return this unit to use as I like the look and that Marantz sound i remember from others I have heard years ago. This is my first Matantz. I plan to recap the power supply at least and will likely follow up with the phono input board.
Any comments are appreciated and I will post any results.
