jonnysocko
Member
I think it's pretty safe to say "clipping" can be added to the file drawer containing politics & religion. LOL!
Technically, accidents are caused by two objects trying to occupy the same space at the same time.
Otherwise I thought the alcohol metaphor was pretty good.
*I voted 'yes' but upon reflection, I suppose that's incorrect as clipping alone isn't enough to result in damage, speaking literally.
while a small amp is clipping (while being played beyond its capabilities), it delivers full power over a long duration and damages the voice coils.
what's NOT to understand?
The reason I redact that is because clipping will not result in damage if originated from an amplifier if it is small enough and/or the speaker is large/inefficient/robust enough.
I think my brain is clipping.
High spl levels are dangerous especially for long periods of time. If you a have a 2 hour party and generate 100db for your guests during that time you are damaging their hearing.
In my living room at 70 db my wife gives me stink eye. At 75 she leaves. At 80 the dog leaves. At 85 I'm probably enjoying it but will only last a song or two. At 90 you can hear it while in the kitchen and no living thing is in the living room. At 95 you can hear it clearly outside with the windows closed and no one is in house anymore. Anyone in the living room will last maybe 15 minutes without hearing damage if they did not do the same thing for the last couple days.
My point here is that I have a rig than can easily generate 95 db in my living room all day long without damaging itself. Just like I have an audi that will go 120mph all day long. I dont do that but sometimes I want to go 90 to pass someone. If I had a stock vw bug I could not do that and would plan my life accordingly. Same goes for audio gear.
Answer this question and the answer is clear - How much power is an amplifier driven into clipping capable of generating? Hint - its a multiplier.
While I could generally agree with you there, what you're doing I think is what others are doing in this poll, using an outlier to provide your findings. An early post in this thread cited a 5 watt amp. However, the vast majority of audio enthusiasts, whether they be 2 channel or home theater, employ amps or amp sections far greater than 5 watts per channel.
Using such small amps is perfectly fine, don't misunderstand me. But for the purposes of this poll, citing tiny amps or massive voice coils doesn't really advance the conversation. This poll is more of a "generally speaking" non-specific poll variety, and generally speaking, clipping does damage the majority of speakers being used by the masses. It may not show up, the damage may be of the minor variety, but it certainly can happen.
Generally speaking, I agree with your position.
However in strict interpretation of the OP's query as worded, and in the absence of any qualifications debarring the "unlikely" or "outlier", the answer would have to be no.
See response, below.
The chief point is that without sufficient power, driver damage will not result from clipping - in & of itself - strictly & technically speaking.
So, how does the damage occur? You seem to be implying that clipping is somehow the culprit...just not really the culprit.
Otherwise, yes clipping is a very real issue indeed and can very well result in loudspeaker damage under most practical applications.
How does this occur, in a practical application?
Is there an equation to determine what that number is using only published specs? The suspense is killin me![]()
To provide a final review of all that we have discussed on this topic, there are only two ways to damage a speaker: Mechanically and Thermally. The only way to do this is by applying too much input power in a given enclosure (mechanically) or too much average power over time (thermally). There is no DC in a clipped signal; the coil does not stand still; air passing over the coil (and thus cooling) is the same regardless of the waveform; and clipping is acceptable provided that the average power over time is lower than the speaker's limits. The next time you hear those famed words "your speakers died because of clipping", remember what you have learned, and above all, keep searching for the truth. It's out there somewhere.
