I would posit that it's perfectly okay to power speakers rated for 75 WPC with 250 watts, as long as you don't twist off to the point of feeding those speakers significantly more than 75 of the available 250 watts. If you exceed the rated power input you can reduce the speakers to smoking ruins pretty quick.
Conversely, if you run a pair of speakers whose minimum power requirement is, say 50 WPC with an amp whose output is perhaps 15 WPC, clipping (or square-waving) can turn your tweeters into raspberry jam if you crank it up.
An oversimplification, I know, but speaker manufacturers put power requirements/limits on their products for a reason -- the speakers are sold with warranties. If you couldn't blow up a speaker by either over- or underdriving it, the manufacturer wouldn't bother putting a minimum AND maximum power rating on it.
Oh, and by the bye, I've personally seen speakers blown up both ways.
