I currently have a 16 ohm Coaxial Alnico just like an Altec 604 with resin dome tweeter, but it is not an altec. It originally had a treated plastic/vinyl paper surround, but I opted to replace it with a pleated cloth surround like the 604D when they went from paper to cloth because the cone was in extremely rough shape. This company also went from treated paper to a pleated cloth on their later models which improved Fs.
I wanted to use the original voice coil and was able to salvage the original voice coil however the new cone has a slightly different profile...
This turned out being problematic because i glued the voice coil to the spider according to the correct original height for the magnetic gap which made it 3/16" too short for the new cone once the hole was cut to the correct size.
To account for the difference I then shimmed the coil pulled up slightly and weighed the cone down so they would meet and I could glue them up.
Technically.... it works and it surprisingly sounds way better than an original that I have as well (I a/b compared them), but it is currently applying opposing forces upon itself (spider being pulled up slightly and cone being pulled down....
This is slightly visible to the eye by looking at the woven fabric accordion and I don't like the fact that this is how it turned out and can't help but think it would be affecting the sound in a negative manner. I also don't think the cone moves as freely as it should.... though I'm not really sure about this.
I did buy an altec 16 ohm coil (before measuring my current coil) but they are 3" inner diameter (76mm) flatwire underhung.
They won't fit the pole piece.
My woofer uses a 3.03 inner diameter coil (77mm) roundwire underhung.
I could not find a 77mm/3.03" coil in 16ohm but I was able to find them in 8 ohm, but they are roundwire overhung. they're in the mail.
I don't want to affect the sensitivity of the driver too much either.. I'm not too worried about the overhung /underhung situation.
Here are my options:
A) I can attempt to stretch the altec coils out 1mm diameter with an exhaust stretcher and re-epoxy them to the bobbins.
I tested stretching magnet wire today to see how far it would stretch and if the coating and ohms would be affected at all and I am safe to stretch them out well over the 3mm I'll need for circumference. I'm just not too keen on this idea.
B) I can use the 8 ohm roundwire overhung and but there will be an impedance mismatch with the 16 ohm tweeter. I'd imagine I could account for the 8 ohm coil with a resistor in series with the woofer? (I think there would be a gain in sensitivity going from a 16 ohm coil to a 8 ohm coil but then a reduction back when trying to match the impedance with a 8 ohm resistor. Maybe i wouldn't need a resistor and a proper crossover would be fine to level match them?
C) I can use the 8 ohm roundwire overhung coil and change the tweeter out to an 8 ohm as well.... I've bought a comparable resin tweeter with 1.5" voice coil to use but it will need to be glued to a 1/16" phenolic ring to sit correctly in the gap further complicating things.
D) I know there is one place that might make custom coils but not sure if they'd just make two and I don't have a ton of money to spend on this project.
I'm leaning towards "b or c" but can't help but think about "a" because it's a proper underhung coil and is flatwound (bonus) which will improve magnetic Flux and frequency response along with keeping distortion to a minimum and is 16 ohms like the original coil.
Any opinions would be greatly appreciated.
Questions are more than welcome. Just looking for some direction. Thanks.
