whoaru99
Epic Member
Here’s a tip - if you input 1 > B > P2 you get 18 min, but 1 > P2 > B gives you 20 min. You can still add the max amount of extra time so you get an 2 minutes of total roast time. I usually let it go to 5:00 remaining then add the max extra time and go manual. I also use 15 oz instead of a pound.
I have not yet tried any of the program modes.
Did a 1:45 second preheat, then
Used 1 (despite using only 1/4lb in the drum) to avoid the unattended shutdown nanny, then P5 for manual 100% power, then watched the roast. When it was getting brown I hit P4 for 75% power and listened for start of 1C.
At start of 1C I hit the A button to reset the timer to show the expected time for 1/4lb to go to 2C. Half way through that time I hit Cool.
I'm going to try a couple different things.
Less power up front, maybe 50 or 75% and more at the end, 75 or 100%
Then 100% up front like I did but cut back sooner, and maybe to P3 instead of P4.
