Today I ordered a DB Systems DB 8 phono preamp tailored to my Sumiko Blackbird. It should arrive by next weekend due to the slight modification in gain etc. When it arrives we will proceed to have a shootout between the Bellari V129 w/ Mullard re-issue tube, the Cambridge Audio Azur 640p, and the DB systems DB8. The shootout will be in two phases - first using the normal gain MM using the Sumiko Blackbird in the TD160 hotrod, then the Denon DL103r in the Technics SL1700 mk2 using the high output moving coil section of the 640p compared to the other two using a Music Fidelity AC1 moving coil head amp, then the 640p MM section using the AC1 head amp as well. I think it will be a very interesting shootout, and I hope to be assisted by Blue Shadow to get a second pair of ears on the output.
Since these Phono Pre-amps are both affordable and well regarded it should be a rare opportunity to compare them in a controlled environment.
To be continued,
Jim
To be continued,
Jim
