Comparing two preamps
jshakoor
I am currently using a Mark Levinson #28 preamp. Have a chance to upgrade to a Audio Research Ref 5. Would it be a substantial improvement to the sound?
I’m also using an Audio Research Ref 75 SE power amp.
Thank you
I'm not familiar with either preamp, nor am I willing to play in that tier of audio product, but . . .
At some point, possibly, maybe with two components such as these, aren't "improvements" more about preference and synergy rather than actual performance gains?
I'm not implying performance gains aren't possible, but at what cost for "substantial"? And of course each individual has to define cost versus value.
At the level of performance you're discussing here is it possible for someone else to legitimately suggest to you if exchanging one component will be an upgrade? I imagine you could even conceivably degrade the ultimate performance of your system, however minimally.
Thank you
Ref 5 is a much newer unit. It will sound different, but if it is better - hard to say without comparing side by side. Unlike all solid state ML, AR is a hybrid design, which uses tubes in part of the circuit. Though AR tube gear is least "tubey" than many other brands. I heard a system with Ref75 and Ref5SE driving Wilson speakers - it sounded very good.
Any chance you can try it first?
I use an Audio Research LS15 line stage with my Mac MC40's. It's the least "tubey" sounding preamp that I have used but not clinical sounding.
Never heard any ML gear.
BillWojo
