Eddie hy fi
Have a vintage sylvania console stereo tube amp that works well but has had a back ground hum in it every since i got it -------ive tried many things and it sounds great but still has this back ground buzz or hum that does not change with volume and even with no input the amp has this same back ground buzz that you really only hear when idle or in quite times of music but id like to fix --------its not the power supply caps or the rca input wires , the amp was a 6L6 amp but some one has converted it to 6bg6ga --the resistors have all so been checked and some changed --the capacitors are nice and good and not that far off factory specs ----this amp has nice warm sound when it warms up and id really appreciate any help , as im not sure what to try next --some say to do something with heater wires , others say to add a ten ohm resistor to the over head high voltage wires , as they may be picking up a radio frequency buzz , what should i try next ? and can someone talk me threw it ? --id did some of the work but the buzz or hum remains no matter what i do , its in both channels , same level ,
