Zonker92
All shiny and chrome
doesn't the schematic show 2 10 Ohm?
Look at R3: 20 ohms. Plus, I've never seen a JBL crossover PCB with two resistors wired into one spot.
what is in the other speaker ?
i agree they do appear to be incorrect values .. i would expect less heat though .
check the other resistors ..they look the same so may have been changed
so I got the board out and connected a meter to the resistors and they appear to be in spec-
the two paralled 10 ohm pair read 5.2 ohms.
Were the two resistors that are paired, mounted any closer to the board than the others?
Makes perfect sense. :yes: Curious to see the other crossover.
No, it shows R3 as 20 ohms @ 10W rating. It doesn't indicate how the 20 ohms is obtained other than with something having 10W rated dissipation.
I think the two resistors you have are someone else's (incorrect) handiwork.
Myself, I'd probably rewire them in series and put them back in. They don't look heat damaged at all, and 5.2 ohms would be expected from two 10 ohm resistors in parallel. Putting them in series should give you 20 watts dissipation capability.
