Just sharing the loveThanks for the riser tip Dave.
50 bucks wow! ! Always a one upper. LOL
Mechanicsburg, Pa. I was a little late to the show.
Don't refinish them too much... New grill cloth and a high grit sanding is all they should get. Raw birch, no finish. Do not apply one...
I have them hooked up to a Sansui BA-2000 using a Marantz 1150D as a preamp.Dave what amp are you using with your Cornwalls? These will replace my KG4s which are currently hooked up to a Pioneer SX-980 right now. Thinking maybe I should start down the tube path in time but I'm clueless about tube stuff (and most audio stuff lol).
I would think a finish is desired for protection. Raw birch (like any wood) will easily stain, soaking up dirt, dust, and moisture. If anything spills on raw birch the staln will have to be sanded away. Dust, humidity, and exposure will eventually turn raw birch grayish. There are threads on the klipsch forums about finishing raw birch. One suggests that to keep natural color and to avoid yellowing which will come with use of oil, polyurethane should be used..
I'd be surprised if Klipsch sold raw birch with the idea or intention that they would not get any finish. I don't that much about Klipsch, but i do know birch plywood.
He was asking $450 with the boxes? Wow, I wouldn't have been able to get the money out of my pocket fast enough.
There's things that make you go "Hmmm" and then there's Cornwalls that make you go2 seconds of "negotiations" and it came out. I'm pretty stoked. They sound amazing!
I did a thorough search here and couldn't find a how to on refinishing these.
That is because wood is wood. There are many threads that include "speaker refinishing" in the title. I have little experience but believe you need to know if they are (a) oiled, or (b) varnish, shellac, polyurethane coated. If (a) you can rub a rejuvenating oil on them. Easy. If (b) then I believe you need to strip them first. I think a basic furniture refinishing article would be a good place to start. Also may be posts over on the klipsch forum (just google klipsch raw birch refinishing). Best of luck.
Can someone please ID what version these are and how much you would you pay needing refinished View attachment 887059 View attachment 887060 and new grill cloth.
Thank you!
I'm still wondering what date is stamped on the back of your new babies?Thanks. I get that. Someone mentioned there was a specific thread on refinishing these so I thought it would be nice to see it and the results.
