Thanks for confirming that the driver board needs to be installed. Yes, the VD1212 replacements are in series not parallel, my bad. The D07/D08 diodes are installed correctly.
So, I've made good progress, but have questions.
1. I adjusted the bias on both channels to 30mv, the DBT died down once these values were dialed down (properly)
2. DC offset is 0ma for both channels
3. Relay is clicking on when powered on!!!! It's taking about 8-10 seconds to click on, for now at least, I need more optimism. Another highlight, for me, is that there is NO smoke this time.
So I think the time spent with the driver board was worthwhile. However,
4. I'm getting volume coming from both channels, but it is very faint. (the tone board is working properly as you can hear the adjustments, FM signal works (it drew in a very good signal without an antenna), I have yet to test the rebuilt phono board, will do that once I've addressed the faint volume level.
5. My meters are not working, I'm assuming that these will need to be reset per the SM 2.2 Power Meter adjustments. I've tried this previously and did not have luck with it, but will give it another go. Would this affect the volume output of the receiver or is this something else?
6. When setting the bias there are three pins (05,06,07) with two leads (03,04). Per the SM, Pin 5 is for the + lead and Pin 6 & 7 are for - leads for left and right channels to set the bias. From my pictures, I have lead 03 going to pin 07 and lead 04 going to pin 06. Can you please confirm which leads should be on those two pins? Asking, as I found another picture where the lead and pin combinations are different.
7. Any instruction on the Power Meters, would be most appreciated. Like I said, I'll give it another go.
So, I think that I'm getting closer to having a working unit. I look forward to your reply. Eagerly yours!!!
