That tests suggests that the turn off (and on) does not have an overt fault - that it IS functioning - but not exactly.
(the overt fault does NOT sense the turn off ac voltage - but rather is influenced by other collapsing voltages that this circuit is supposed to BEAT!!)
BUT....That suggests that the relay opening IS being beaten by some other turn off transient.
The ONLY way I can see that happening is that the protect off signal is being slowed down by something.
Now, as far as the turn off:
- D8 rectifies the 7.5v ac turn on / turn off signal from the lamp circuit.
- R25 2.2k charges C5 4.7uf, but R24 15k forms a voltage divider with r25 - limiting the voltage (negative voltage!!) on C5.
- Then THAT negative DC voltage (-5.1) modifies a bias on Q6 (R29 4.7k) that comes from the -13.5v supply.
- EVENTUALLY Q6 is turned on (base goes 0.6v positive of the emitter (which is grounded)
The original q6 is 2sc945a. The kit Q6 is ksc2383, which is a transistor who's die has a greater Safe Operating Area (the ability to handle an instantaneous burst of heat) to handle the energy of discharging C6 100uF through R27 22 ohms. Eventually C6 is discharged enough that the base of q7 is no longer 0.6v above it's emitter (which is RAISED up from ground by about 8 volts by the current of the relay coil flowing through R28 220 ohms.
Complicated - with MANY time constants interacting in a chaotic looking (but elegant to me) dance.
EVERY value of component varies the time constants - and you / we are looking for a change (intentional or not) that SLOWS IT DOWN.
Too big of a cap?
First, try it with the original relay. look for the pop.
If it goes away, well, TELL US. Head scratching SQUARED time. wonder if it's a Omron DPDT LY2F-AC24 with a shading ring on the pole. THAT would DEFINITELY slow the relay release. DC fed into an AC relay can pull in the relay coil, at the expense of a slower release.
Try it with the original Q6, look for the pop.
then leave Q6 in, and put back in the Original Q7, look for the pop.
Gain on Q6 or Q7? hmmm....
Looking at mouser.com - backtrack to EXACTLY the part number of the relay that you paid for, then read the markings off the component.
