Your point is well taken. The short answer is the expense is not so much the issue as the time.
Originally, I had intended only to clean it up and enjoy it, and possibly do a few minor repairs if necessary. Quite honestly, if it had not been an SX850 (and an especially minty one!), I would probably would have given up on this "pop" issue and broomed it.
The Protection Board was re-done earlier, as a first attempt to fix the pop. It was a full "refurb" with caps, transistors, diodes, zeners. But now that the Flat Amp and Power Supply boards have been partially disassembled and are accessible, I plan to "refurb" them as well. I've already submitted an order for new caps, transistors, etc.... Not sure yet if I'll change the transistors, but at least I'll have them on hand. At that point, if everything is working well, I will probably leave the other boards.
By the way, what do you think about the dramatic difference in audible hum, between channels, when touching the pre/out jumpers (ref. post #27). I'll re-verify it's there, after completing the Flat Amp and Power Supply boards. But doesn't seem related to the "pop" noise. I'll start a NEW thread on this problem, if it's still there.
Thanks, again, for all your excellent (and patient) help!!
