brandysparts
Hello, I am currently trying to fix my fathers old Onkyo A-5 Integrated Amp. It would not start up or give any inclination that power was going through it, so I spent the past few days trying to figure out why when I discovered it was an issue with the thermal fuse in the power transformer. After attempting a bypass of it, I was greeted by it turning on which was a very welcoming sight. I was also then greeted by the smell of a burning resistor, which then promptly blew and caught fire which was promptly extinguished. The resistor that blew was named R638, and I cannot find it on the schematics for whatever reason, so I am a bit lost as to what sort of resistor to use, and could use a bit of help there. I am also looking for advice as to why the resistor blew in the first place, as I am unsure if its just because of the age of the system and being in a moist environment for two days, which I believe is the reason it failed 2 decades ago, or if its because of something I have done wrong. I appreciate any sort of help or advice you can give me, and I hope you have a wonderful day!
