I got a CR-2020 recently that had some issues on the right channel, and I slipped while probing it and created even more issues. After all the dust settled, I'm left with a right channel that I can't get the bias voltage below 20mV. There is also more THD on the right channel than the left.
I was swapping parts between the left and right channels to try to find the source of the distortion, but wasn't able to trace it to any transistor. However I wasn't checking the bias setting while doing that. Currently, the left channel has the original TR611 and TR612, and the right has replacements, MJE15030G and MJE15031G. The right side also had TR609 and TR610 replaced with the original part numbers, but left has the originals. Both channels had TR613 replaced with MJ15003G, TR614 with MJ15004G, TR604 and 605 with 2SC2240, and I replaced the trimmers with a 25 turn bourns 50k to try to make the adjustment less fiddly. I also replaced a few out of spec resistors, and FR601 on one of the channels was blown so I replaced it with a 100mA fuse in series with a 68ohm resistor since I couldn't find a single replacement part.
Currently the bias adjustment is my biggest concern. I could try swapping TR611/612 between channels to see if that's causing it, but even that's the cause, what is the fix? Are there better replacements for those parts than what I picked? Also does anyone have any ideas about the distortion I'm seeing in the right channel? The distortion is definitely coming from the right amp board as I've swapped both the inputs and outputs to it to verify. This output was with a 50mV signal split into both L&R main in terminals.
PS: even with the 25-turn pot, adjusting the bias on the left channel is super fiddly. Is that normal on these units?
PPS: the right power/signal meter isn't zeroed. Is there a way to do that?
