Mike1767
I have recently brought home a 2020 from my parent's basement that I am hoping to bring back to life. Growing up, it was my Dad's pride and joy, but it has now been sitting unused for too long. I am half decent with a soldering iron and multimeter and can read a circuit diagram, but I can't troubleshoot my way out a paper bag.
Here's what I know. The unit powers up, lights all lamps, FM tuner meter swings halfway left then doesn't move and the relay never clicks on, so no audio. The service bulletins were all done a number of years ago. I replaced a half dozen caps on the power supply board that had shrunken wrappers to no effect.
After reading a number of threads and seeing the common asks for measurements, I made the attached image with the readings that I've taken. Hopefully it's legible on here, it is at full size. In addition to what's on the image, I get +/- 61 VDC at the output transistors and the idle current measures right around 10mV.
There are a couple of obvious (I think at least) issues in the measurements I've taken. The biggest standouts are emitter on TR714 being in the millivolts, the base of 715 being +8.6 VDC and the -25 post reading +8.7. My problem is knowing the source of any of these issues. Any help you could provide would be great. Thanks!
