I tested main amp with dummy 4.4ohm load with 1kHz signal and after positive signal clipping few seconds then fuses (F801-804) burned. Then I removed all main amp transistors TR717-720 (4pcs) and measured them, all was ok.
Then I tested main amp board without main transistors and output voltages were -39V (TP3) and -26V (TP4), also R744 (820R) smoke came out.
I would guess output voltages should have been around 0V also without main transistors, is that correct? I just want to test 1st main amp circuit to work correctly that I do not burn main transistors.
I have not done any modification to this amplifier. This amp feedback circuit is not familiar to me but it seems that feedback is working without main transistors.
