So Vbe is about 0V, suggests "no" current flow so no volt drop.TR707 pins to ground: B +34.1vdc, C +36.2vdc, E +34.1vdc.
Make sure your test probes/grabbers are making a good electrical connection. Component leads are likely all suffering from minor oxidation by now.The voltages on all pins of TR711 and TR713 are very unstable.
TR711 all pins reading approximately -21vdc, jumping around a lot.
TR713 E and B approximately -21vdc, jumping around a lot. Collector was so unstable it was hard to assign a value…..
Unstable TR711b would point to TR705, TR701, TR703.TR711 all pins reading approximately -21vdc, jumping around a lot.
Need to totally remove all traces of carbon from that divot! I would use a dremel cutting disk. Make a thin, shallow, slice between the traces and cut just deep enough to clear the burnt part of the phenolic from the board. Carbon is conductive!This is TR806…I was thinking of some non-conductive epoxy on a toothpick? So I have not yet repaired.
