Nuklhed
Recapped the 820, including the filter caps which had degraded to about 75%. Deoxit all switches. No left channel. Swapped the output trannies made no difference. Replaced all left channel diodes and transistors 701-721 in left channel. Found fuse resistor FR701 open. Replaced it with a 68 ohm resistor. As soon as I turn power on, that 68 ohm resistor burns up. Thoughts?
It would make things real interesting.
