pdxtim
Well-Known Member
While adjusting one channel of CR1020 for bias the pressure from the screwdriver tip on VR 602 seemed to cause the voltmeter reading to jump around quite a bit. I was able to adjust to 10mV though and unit sounds good. Following advice here on AK I replaced the VRs on my Sansui G7700 even though sound was fine. Does the same apply to the CR1020, should VRs be replaced even though there’s no problem or should I leave well enough alone? Thanks for any advice.
