You don't want silicone anywhere near your speakers. Nasty stuff that contaminates everything around it.
Use 3M VHB tape.
Sounds clean and easy.You don't want silicone anywhere near your speakers. Nasty stuff that contaminates everything around it.
Use 3M VHB tape.
Silicone contamination is known to have a negative impact on assembly processes such as soldering, adhesive bonding, coating, and wire bonding. In particular, silicone is known to cause de-wetting of materials from surfaces and can result in adhesive failures.
The gas emitted by the silicone sealant (acetic acid) is corrosive.
You sold me on the tape idea heading to home depot in the morning...Thanks for the input..Perhaps this will help.
I tend to think that once the silicone RTV cures, there is no danger from acetic acid - that once cured, it's inert. Silicone lubricants may be the cause of interfering with adhesive bonding, soldering, etc. In my trade I have seen RTV used very liberally by less than skilled craftsmen - "organ technician in a tube". The only problems I noticed were difficulty getting things apart because it has a very strong bonding agent. But this brings up an interesting point and bears further study.
Hey, what's the beautiful crossover doing in your grandma's old mattress?
Well I tried the 3m vhb tape and all I have to say is total crap..So I put gorilla glue on it seems to have worked pretty good..Hot melt glue is utter crap for crossover capacitors. I've lost count of the number of large loose caps (and some inductors/chokes) vibrating in speakers due to that stuff. It gets dry and brittle, shrinks and falls off or simply lets go, particularly after several years and at low temperatures. The only good thing about it is how easy it is to pick off a component.
I second cable ties, at least two per capacitor, tied down horizontally through holes in the PCB/board whatever. Easy to remove with diagonal cutters but very strong and don't vibrate.
