Wondering how good or bad pcbs are for crossovers. There's track thickness is it sufficient, are tag boards better, is wood better.
There's microphony, commercial pcbs have all the components glued very firmly to the pcb, but doesn't this just make everything vibrate, for some strange reason I wonder about drilling holes to allow airflow, or pressure wave flow through the board, avoiding tracks obviously. Should crossover pcbs be mounted on springs and dampers or bolted down to the cabinet!
Is the tweeter inductor better off mounted in foam.
Questions questions.
Thank you
Thank you
