Lavane
Lunatic Member
Motor run caps can be great for crossovers and filter caps. Even the oil filled type. Those that I found at Partsconnexion were motor run caps as well with great specs. I never get into the weeds looking at film caps. Some of the crazy expensive boutique film caps don't test well at all. Janzen does produce some very nice caps though. So does Mundorf.It seems like assembly and testing would be easier with the crossover mounted on the terminal plate/cup.
The electrolytic caps are about 40mm long x 18 mm dia. The film caps are always larger than similar value electrolytics used in crossovers. The electrolytics are typically 100V rated parts, which keeps their size and cost down, and the PP film caps with the same capacitance are typically 400-600V rated parts which makes them bigger than if they were also 100V parts. I suspect the film caps used in crossovers are rated for high voltages because they are also used as coupling caps in some tube circuits.
I had two and kept one Marantz model 140 power amps and restored them at the same time. The only difference between them when done was the film caps I used on the amp boards. I left the original film caps in one, and used Janzen Superior Z caps in the other. The difference in how the two sounded was very noticable. The amp with the original film caps sounded a bit sterile compared to the amp with the Janzen caps. Thats the only time I ever noticed a real difference in film caps. I build my own tube amps and use a lot of Panisonic ECW polypropylene film caps for bypass and coupling caps. Those and those axial yellow Illinois polypropylene film caps. They sound good and are dirt cheap.
For crossovers I use Audyn, Solen, and Dayton usually.
