JamesML
Well-Known Member
Have installed this motor in a Transcriptors Hydraulic Reference Turntable to correct what I thought to be a slow running motor.
Alas, despite successful install the turntable is still running slow.
I have cleaned the main TT bearing and re-oiled, cleaned all pulleys, replaced the belt and done everything else I can think of.
The purpose of this thread; I was wondering about oiling the motor bearing and how to do this. Showing my ignorance about such things; Not for the first time.
There seems to be a tiny hole (see pic) offset from the centre of the motor top plate which might be the place for lubricant (I'd use sewing machine oil). But, I'm not sure.
I wasn't even aware that this type of electric motor should even be lubricated at all.
Any offers of help or advice on this topic would be appreciated. Criticisms are also welcome.
I don't pretend to be a tech guru. I've fixed lots of audio equipment in the past, mainly electrics, but the practical mechanics I usually steer clear.
Thanks in advance.
Jim
Thanks in advance.
Jim
