waggs098
So I have the above amp powering my mains. Thursday I came home from work and my son was listening to music and shortly after he shut it off. I turned it back on about 30 minutes later and channel 1 had low output and sounded slightly distorted. I didn't notice it when my son was listening.
Did all the typical things like swap speakers and inputs to the amp to determine the amp was the problem. Pulled the CE 1000 out and put in a different amp and all sounded fine.
Yesterday after work I hooked the amp to some test speakers and, as I figured would happen, it works fine. Left it on for about 2 hours to get warm and played music for about an hour and no issues. When it was in my system to only thing I didn't move were the speak-on connectors at the amp so I suppose its possible there was a bad connection there but seems unlikely.
The amp hasn't had any issues previously.
Anyone had an issue like this with one of these?
I'm going to check DC offset and bias. Aside from that what else should I check? Only thing I can think to do is compare voltages to the schematic and see if anything looks off.
Thanks for reading and any help.
