CT-F1000
Noneya
I have a problem - picked up a CT-F1000, and upon closer inspection discovered that the spring-loaded spindle caps (the best I can describe them) are missing. The sleeves must have cracked (at least the one on the right has a hairline crack) and the spring and the cap popped off...:rant:
I wonder what my options here may be... Does anyone know the parts numbers and are these an unobtainium kind? I looked at the service manual, but it's not obvious what they might be,..
Any advice would be much appreciated...
This is a picture of the whole assembly I’ve had several of these decks and most of them have cracked spindles doesn’t really seem to affect it the pin still holds tight enough that they work You’ll have to keep your eye out for someone parting out one of these units hope this helps
Thanks! So, do you happen to have the part number(s) ?
They only list in the service manual the part number for the full assembly this might help
