Lance Lawson
I decided rather than trash my new reel of sticky Ampex 407 that I’d try the Nu Finish remedy. I did however spool the 407 on to one of my cheapo gray reels . The nice Ampex reel and box now houses RMGI LPR-35 but maybe that was a premature decision.
Anyway I set the reels on my TEAC going directly reel to reel bypassing the transport. From there I saturated a cotton disk swab with Nu Finish. I hit fast forward . I stopped every 200 ft to reload the swab and turn it to a counter pointing angle. I proceeded to the end then did the same procedure in rewind. I repeated the operation three times. Once I was certain that I had done all I could and the swab was picking up less crud I took a clean dry swab and rewound and fast forwarded the tape twice. Gradually the swab ran cleaner and cleaner. Then I removed the reels and put NuFinish on all the guides and cleaned the facia. This stuff is nice and it works great as a polish.
Then it was time to test the tape. I loaded my newly purchased Counting Crows August And Everything After CD. I love this collection and have only known it on cassette since 1993! I set the levels and put the monitor into off the heads mode donned the Sennheiser 280’s crossed my fingers and hit record. Rround Here came off the heads through the headphones loud and clear, picture perfect! Ok so 3 minutes of good recording…big deal! Omaha repeated the performance of Round Here and midway through I said “Hmmm maybe there’s something to this.” By the time Mr. Jones screamed across I knew this reel of tape had been saved and saved well! I couldn't help but laugh out loud and I watch the VU's pegging to this classic song! This is Ampex as I remember it and I know why I loved it so much! Well the entire CD recorded perfect and even though I had tortured the tape when first run as it stuck to the transport a half dozen times and it bunched up and twisted more than once! But this didn’t seem to matter! There’s no dropouts or indications that the tape twisted! But more importantly it runs and runs fine. Also it sound amazing just as it should!
So whatever is in Nu Finish it does seem to cut and into the bad layers of coating and it also seems to coat the tape and act as a lubricant for both the tape and transport. Call me an optimist but I have the feeling that this stuff does a better job than baking. I think using it before baking is best as the last thing you want is to have the unstable coating stabilized so it can’t be removed by the Nu Finish. Maybe bake it after just for good measure? I wouldn’t bother heat treating the tape as this easy enough and more or less mess free. Lastly the tape now spools even just like normal tape should!
This is the treated reel and bottle of Nu Finish.
