Don't get me wrong I am not claiming that I can hear a difference between USB cables per se. I am stating that a difference can be heard between usb cables with power lines activated and those with power lines inactive.
As for the above descriptions on how usb cables work, that seems to be in line with my understanding. I am, however, confused on one point. Some have stated that if the information packet is corupt, the dac will 'notify' the transmitter and the transmitter will then resubmit the 'packet'. What happens to the music at this point? The music has to continue and if the 'packet' is corupt, it is my understanding that the dac will drop that packet leaving a whole in the data. Waiting for the packet to be delivered a second time will surely interfere the pace of the music. No?
Also, it is my understanding that every dac handles variations in the voltage differently. I.E. if 0V represents a 0 and .5V represents a 1, what happens if interference on the data line causes the voltage to be .25V, for example. Or .35V. What the DAC does with that can vary between dacs resulting in a difference in sound caused by 'dropped packets'. i don't think this is a huge problem but I do think that the insulation the usb cable has, can help maintain a more precise voltage as the electrical signal makes it's way to the dac.
Has anybody tried my experiment of covering pin 1? I am curious if anyone else has noticed such an extreme difference -- of course you do need a d100 for this, as most dacs require the power line to function.
