ANoteSupreme
One of the tweeters in my Dahlquist DQ-10s is blown. (Came back from a work trip a few years back to find a tweeter fuse blown and my Minor Threat CD sitting out on a table...) Took it apart to check and the film was physically torn. I "repaired" it by spreading a thin film of polyacrylate glue over the tear, and it has played OK, but not great,
that way for years. Some serious distortion on certain notes especially in loud operatic solo vocals, and raggedness in loud classical music ensemble passages which I attribute, perhaps wrongly, to this damaged tweeter.
I'm wondering whether the same tweeter was used through the whole manufacturing run of DQ-10s. I have
the factory-mirrored version from relatively late in their history, serial numbers in high 45000s. The tweeters
in mine are mounted above the "mid-woofer", with their particle-board backing attached to the mid-woofer's
backing. I have considered purchasing a used DQ-10 tweeter I saw online as part of a similarly attached dome-tweeter and supertweeter assembly--- I'm assuming this assembly came from a different configuration, perhaps the earlier non-mirrored ones? The tweeter looks similar, but the metal back cover does not have the white "Made in W Germany" lettering that mine does.
I've seen it said that the DQ-10 tweeter was the Phillips AD 0160/T8, and I'm also aware that the original DQ-10 tweeter isn't made anymore. I just want to be sure that the used tweeter I'm considering is the same as the one I'm replacing (I know I won't have the benefit of a matched pair) before purchasing, especially since it's not cheap. I've seen various suggestions for non-original equipement replacement, and would consider those if I can't find good used originals, but ideally I'd like to keep the speakers as close to original as possible.
I also considered replacing the two electrolytic caps in my crossover, but they don't seem to be visibly deteriorated. Also, figured I should replace one thing at once and the tweeter is the most obvious.
Thanks for any advice you all have!
