Hello folk,
Life has been good to me, not so much visa versa ... As the recent few months have been more than exceptional,
luck / providence dropped Realistic's better made receiver in my lap (STA-2000) and a complimentary pair of Mach one speakers.
This configuration lead me to look into the systems compatibility and possible better suited speakers to replace or compliment the new. find.
Little research was required to soon realize that my taste outweighed reason and my budget.
So I dug into my own reserves (attic) knowing full well that the sub woofers in at least two pair would need to be replaced.
The Mach one speakers are fine enough, now that I've ran them through the gauntlet, although leaning more toward the bass.
The mid's and tweeters have been constructed with a wide range response in mind, placement is key as well as tweaking balance, treble, bass and volume to suit.
After removing the subs from the dusty Mission 700's and DB plus 880's (both are classified 10 min. 100 watt max, 8ohms) .
Time to experiment , (to much fun for a now greying kid)
The ( soft mid's ) in the 880's presented just the right desired frequency and surprisingly more than suffice, adding just the right level of balance to the systems high range demands.
The Missions do have a better built cabinet and reputation (made in France/England) assembled North of the 48th (Can.)
with much love and ascetics, which will be the more sought after replacement / rebuilds .
For now, I can relax and entertain my dogs who more often look to me in wide eyed wonderment ?
(the sky is falling)
Right DAD! You know it ...
Than you all
Axel X Kane
