special_20
I have a DBX-BX3 that seems to be in melt down mode!
Background: I bought amp awhile back and had it sitting in the pile project. Decided to dust it off and clean it up. It had what seemed to be classic issues with dirty controls and dirty relays making use somewhat intermittent and unreliable. Took unit apart, cleaned up insides and cleaned front switches multiple times with deoxit but it was still acting up so I decided to just bite bullet and replace the relays
So,after replacing the four channel specific relays and Q7, I reassembled the back panel and brought it up on a dim bulb tester. No shorts I then plugged direct to outlet to check bias and offset. I started seeing smoke. I have burned resistors R31, R33, and R34 on the front right amp board. Same resistors are showing the start of scorch marks on the back left amp board. Front left board was running hot. Manual on this unit is less than stellar and doesn't have voltage listing or great diagrams. I'm a bit at a loss on how to trouble shoot. .
My thoughts were to pull the board and check Q12, Q13, Q14, and Q15. Curious if I should be suspect of something else though given problem is manifesting on multiple boards (power supply, protections cirucuit etc).?
- I replaced all 4 speaker output relays.
- Fixed a faulty LED on the front panel that has caused some other users grief.
- During testing I did accidentally short out Transistor Q7 on the protection board (original was a 2sc2705; replaced with a ksc2383).
- Confirmed resistors R28 and R29 were still good
