I "recapped and repaired" a couple of 118s. One needed a 5-transistor array, the other worked OK as it was, but they both perked right up with new caps and new op-amp chips. I enjoyed playing with them. All-new electrolytic caps, new tantalums, even new ceramic caps. And I tried a couple flavors of op-amps. Even upgraded the output caps to tight-tolerance film caps. I was impressed with the results.
The two 118s I have are about 3000 apart as far as serial numbers. (s/n 1211 vs. 4217) The main, and the daughter circuit boards are very different. I didn't expect that.
Bought a 1bx to see how it compared with the older 118s...and then never got around to listening to the 1bx. I'd planned to re-cap it but didn't find time.
I got a "200" switch-box in a package-deal on eBay. I've never had that connected, either.
Picked up a Subharmonic Synthesizer (120X, maybe) for cheap. It's sitting on the same shelf as the rest of the dbx stuff.
One of the 118s, and the switchbox, and maybe the 1bx will eventually find new homes.
