cafe latte
Addicted Member
The armature was not hardened, I have the whole spec of them. John used to recieve them formed up but without the bend and he bent them up, if they were harened they would crack when he bent them.My memory is that armatures also were treated cryogenicaly, which hardened them and improved response.
For those who haven't owned a Decca or perused their literature, they are unlike conventional cartridges that have the stylus fixed at close to a right angle in a cantilever which is in a damper suspension to allow it to wiggle. The Decca, by contrast, has the stylus at the tip of a thin piece of metal that points down from the cartridge, and the stylus is restrained from being swept away by the movement of the record by a nylon cord. This piece is called the armature, and because it is ferrous, when it moves, it disturbs the magnetic field which three coils read in a completely different electromagnetic scheme than close to all other cartridges, which is why the Decca only has three output pins ( and the perversity of Decca in refusing to add a fourth pin connected to the third pin so that normal humans could use it without lengthy explanation (and to make them normal size - they wanted you to use sleeves and solder to them(!!!!!)) goes some distance in explaining why the greatest cartridge in the world never got much headway.
That said, I think (and it is easy for me to say because I'm not putting my money up) that, given the prices Deccas go for, twenty grand would be amortized fairly quickly.
Chris
