GPJeff
Can you describe what the #15 does for you? Also, since you use such a similar method to mine - how do you clean your brushes? And how often?
#15 Solution- From what I read, it's suppose to break loose the tough stuff before you start the 3 step solution process. Now that being said, I really have no way of gauging how much it really helps. I know the 3 step solution works well so I'm trusting the #15 is adding to the process. I usually use it on the second hand stuff that I want really listen too or convert to digital. Since I am spending time cleaning the record, I don't mind the extra step.
After I have the records cleaned and stored, I will use the pure water for a rinse in the future for a light clean up for playing if necessary or before recording to digital.
Brushes - I clean them with distilled water after a cleaning session and let air dry on the kitchen sink dish rack. I usually max out cleaning 10 lps in one sitting, that's about as much the fiancee can handle with the vacuum. With that low number of lps and cleaning the visible stuff off before the 3 or 4 step process, I'm not that worried about cross contamination.
How often do you clean your brushes?
