Dennis Murphy Pioneer SP-BS22-LR DIY Modifications
What's the trick to getting the iron core inductor and components off the board. I tried prying, that just produced some cracks in the board.IMG_20230131_182854_01.jpg
Yeah - those are stuck down really well! I used a heat gun to soften the glue and then slowly pull parts off the board. If I remember correctly, I still had to scrape a few spots.
I'm using a 1.5h air core inductor in place of the iron core and single .5 air core . Further reading has me wondering how the increased DCR will effect the design. From what I've gathered it can effect sensitivity and qts. PXL_20230223_000012642.MP.jpg
Edit. Some good reading that comes to the conclusion it doesn't matter between the iron core and air core. So I've probably wasted money on it. https://hificompass.com/en/projects/experiment/test-couple-iron-core-inductors
I wouldn't sweat it. That iron core in the stock crossover is pretty thin wire, so you may not be too far off from the total DCR.
Hi folks, I figured I would give this a go after using these speakers for six years.
I decided to drill the holes in the board before doing anything else, so that if I messed up that step then at least I haven’t taken the speakers apart yet. I don’t have a drill press so I did it freehand and it came out a bit messier than I had hoped. I wonder if someone can look at these photos and determine if there might be any issues before moving forward? Just wondering if I should proceed or order a couple more boards to try again.
I know I’ll have to install a ground trace jumper wire on of one of the boards since I foolishly drilled the trickiest hole first. After that one, I decided to drill copper-side-up and that seemed to give me cleaner and more precise holes.
As noted, on the first board you completely wiped out the ground trace at location A15. Not a big deal, just install a jumper wire between locations A13 and A17 and you should be good to go. The second board looks much better. No jumper required. No need to order more boards.
Thanks, yeah I really did a number on that one. Hopefully the rest goes more smoothly.
This tip should be added to the instructions. I hit the same issue, but by dumb luck the first hole I chose to drill was on the other side, so I didn't have to make any repairs. One bad hole, drilled the rest copper side up and everything came out nicely. Maybe that's a rookie mistake.
I wasn't able to source an original Radio Shack board (especially in Europe, where getting hold of something Radio Shack would be as hard as finding a pair of BS22s), but there's a company in Poland making clones of them, which meant I could follow the instructions to the letter instead of having to figure out how to map the circuit on to a different project board.
Oh, and Digi-key didn't pack the tweeters properly. I had to suck the dome of one of them back into shape. Seems no harm done though.
MCM_Fan, my ears thank you and Dennis for your efforts. That's one more successful DIY pair of AAMs, in case anyone's counting.
After 10 years, you finally got to it?
Hey, I was wondering if anyone could help with the modification. I want to start out by saying this is my first time working with crossovers. I have no experience. I am also relatively new to soldering. The only time I have used a soldering gun is for my DIY subwoofers, but that is very straightforward.
I botched the original PCB and am working with a piece of MDF.
Here's where I am at so far.
I will most likely glue everything down.
Can I mount the one mH iron core along with the resistor and capacitor on the other side of the mdf? Or will the air core interfere with the Ironcore through the mdf>?
If none of what I am asking makes sense, it's because I am green.
Thanks in advance.
You should be fine if you keep the iron core down at the bottom under L2. The rule of thumb is 3 inches, but since these are in series to make an effective 1.5mH, it's not a problem.
Hey, Thank you for your reply. Just for clarification, when you say at the "bottom under,." Are you referring to
Or like this
Both options would be on the other side of the MDF. I have read "down at the bottom under L2" too many times, and my OCD is nitpicking the verbiage.
Either one is fine. I just measured a 1.5mH steel-core and then placed a .40mH air-core directly on top of it. I saw no difference on my cheap little LCR meter.
No problem. I was curious to see if there would be any difference.
Madisound's 15 AWG Sledgehammer inductors have holes on each end of the laminate. If you are in a pinch and need a slightly higher value, you can use steel bolts to raise it nearly 10%.
Okay, so I soldered and zip-tied a few things down. I feel like I am in the home stretch. Apologies in advance for what looks like a hack job, most likely because it is, it's my first time. I see the appeal of using a PCB board.
I went ahead and connected the positive from the binding posts to C3 2.2UF as well as L2 O.5MH. I drilled a hole and shot the cable up.
My next question is about connecting all the grounds together. Again, I see the benefit of a PCB with pathways instead of creating them with wires.
Is the woofer W+ going to be soldered at the same junction as the C1 & L1 and W- going to R1, -binding post, L3, C2, TW-? Do you just tie up all the grounds together?
429637842_1120693466018103_1759630429663752312_n.jpg429782581_375826422054182_1126575438128991568_n.jpg
Sorry for the late reply. You are actually looking just fine. Point-to-point crossovers can look messy, even in some commercial speakers.
I try to use a star ground approach, but that can't always be accomplished on bigger crossovers.
View attachment 3134678View attachment 3134689
One thought concerns the use of the zip ties for anchoring your various components. I have had some zip ties purchased in the past 10 years that degraded really quickly in room temp conditions. Just an observation!
I was thinking about doing the Murphy mods on my SP-BS22-LRs, but when I priced out the parts list I found this on Parts Express:
Jantzen Audio 2.0mH 15 AWG Air Core Inductor Crossover Coil $38.12.
With the discount for four, these inductors come to $146.72 + tax.
Is there a significantly less expensive source for these inductors?
