Gl-dunk-27
Hello all, I am trying to repair my said AVR after it started going into protection blinky red. Have some knowledge of electronics (college courses in the 90s
) and do solder here and there.
Service manual for this AVR is here.
So far, successfully replaced 7912 voltage regulator in the Regulator board, after which it did come out of protection and proceeded showing the receiver mode, tried changing to last mode and then turned off again. Did some check and turned out that a zener diode on digital pcb was short with some resistor (long leg bent over the resister leg and shorted). Replaced that with one ordered from Amazon. Also, removed some caps and resoldered back after testing.
Now, it shows up that it powers up and goes solid white led (always been white instead of green, maybe previous owner diy). However, display on panel is blank and no relay click.
Have tried reflowing all solders, checked almost all components, relay and voltages. Found a few odd things but need someone’s help to identify if my understanding is wrong. Adding images. Here we go:
- Even when not powered, seeing 5.2V at the output of this SMPS board into the regulator board. Is this right?
- In above case, relay has 120V AC across it. Is this right behavior or something is short?
- Power Relay is not clicking when in circuit even when it has 120V across it. Why?
- Transformer input resistance (blue black wire) seems to be just 1.5ohms and 4.5 for some output wires, don’t remember which one. Voltage across is 0, so 120V comes across to relay, is this right behavior? Transformer probably is alright but not sure.
