Yeah, I was checking around that area for the voltages. IC751 does seem to receive 3.3V and CN753 does have 3.3V at pin #2. See attached image of CN753. Pins 3,5,8 (my numbers) are 0 and the rest are 3.3V. Also, the volts mentioned on the board (see attached) are also correctly coming when turned on. Couple of other things. IC (F0, N8) shows 5.2V at F0 and 3.3V at N8 pins respectively even on off state. I have also captured voltages for IC732 for on/off state. Will attach in next post. Voltages at couple of smd transistors were 3.3V at center pins but 0 on opposite side for both pins, while for some other transistors (in the pic) it was 5.V at center pin, 5.2V at opposite one pin and 4.6V at the other pin. Also, volts at CN762 were around -2.0V when in on state.
